sink drains
jefflaw35
sink drains
Post by jefflaw35 »
is it still legal to have your sink water drain directly out? or should i reroute to waste tank.
We call it Grey water and in our parts, you can drain overboard. Including shower water.
Your cool for now
Muskokan345
Post by Muskokan345 »
Drain overboard. One question though, as I look under my sink, there is a loop in the flex pipe, creating a trap arrangement, is this necessary as it drains overboard, or is there a reason I am missing, like critters climbing in that way.
1986 F26
The loop is so it doesn't syphon sea water back into the sink...It creates a "Break".
jefflaw35
Post by jefflaw35 »
hmmm mine was straight, so create loop, CHECK!! Paul i was expecting that answer, think maybe i will run bothways with a gate valve so when the time does come I will be ready with having to do extra work. its all open now, think it would be a smart move?
jefflaw35
Post by jefflaw35 »
Muskokan345 wrote:Drain overboard. One question though, as I look under my sink, there is a loop in the flex pipe, creating a trap arrangement, is this necessary as it drains overboard, or is there a reason I am missing, like critters climbing in that way.
thanks for bringing that up, i wouldnt have thought of it as mine didnt have the loop, good call!
Muskokan345
Okayyyyyy, If sea water came up that far, wouldnt I have bigger problems?
1986 F26
Torcan
Post by Torcan »
Muskokan345 wrote:Okayyyyyy, If sea water came up that far, wouldnt I have bigger problems?
My thoughts exactly, I was thinking "HUH"????
http://www.cbyc.ca/
If your drain through-hulls are near the boot stripe, as most are, on turns, rocking or with splash, while underway, the opening creates a syphon... and vacuums water into the through-hull opening, much like the venturi effect.
Air, will stay at the highest point in a loop. Water trying to back fill can't flow past this block of air, and such, we have a "syphon break".
Get it now..?
In the 26' siphoning isn't an issue. The drain on the galley sink are normally straight out and about 18" long. If there's a bend in it to form a trap, its to keep wind from whistling thru the drain at the dock. :) And oh yah, if you have water up that far in these boats you are probably swimming.
Vitaliy
Post by Vitaliy »
all my drains on the f46 go streight overboard except for the heads and its perfectly legal
Vitaliy wrote:all my drains on the f46 go streight overboard except for the heads and its perfectly legal
Yes, some are straight and some aren't. Heads, genny's etc use a syphon break.
Muskokan345
Paul, I'm with you, not the swimming part, the part about straight out from sink drain. I figured it was probably a PO, that thought you needed a trap, for whatever reason. Thats the way its been on both my other boats.
1986 F26
jefflaw35
Post by jefflaw35 »
all of mine are even right above the water line stripe
