sink drains
jefflaw35
sink drains
is it still legal to have your sink water drain directly out? or should i reroute to waste tank.
We call it Grey water and in our parts, you can drain overboard. Including shower water.
- Muskokan345
The loop is so it doesn't syphon sea water back into the sink...It creates a "Break".
jefflaw35
jefflaw35
thanks for bringing that up, i wouldnt have thought of it as mine didnt have the loop, good call!Muskokan345 wrote:Drain overboard. One question though, as I look under my sink, there is a loop in the flex pipe, creating a trap arrangement, is this necessary as it drains overboard, or is there a reason I am missing, like critters climbing in that way.
- Muskokan345
My thoughts exactly, I was thinking "HUH"????Muskokan345 wrote:Okayyyyyy, If sea water came up that far, wouldnt I have bigger problems?
http://www.cbyc.ca/
http://www.cbyc.ca/
If your drain through-hulls are near the boot stripe, as most are, on turns, rocking or with splash, while underway, the opening creates a syphon... and vacuums water into the through-hull opening, much like the venturi effect.Muskokan345 wrote:Okayyyyyy, If sea water came up that far, wouldnt I have bigger problems?
Air, will stay at the highest point in a loop. Water trying to back fill can't flow past this block of air, and such, we have a "syphon break".
Get it now..?
In the 26' siphoning isn't an issue. The drain on the galley sink are normally straight out and about 18" long. If there's a bend in it to form a trap, its to keep wind from whistling thru the drain at the dock.
And oh yah, if you have water up that far in these boats you are probably swimming.
Yes, some are straight and some aren't. Heads, genny's etc use a syphon break.Vitaliy wrote:all my drains on the f46 go streight overboard except for the heads and its perfectly legal
- Muskokan345
