10m mid cabin express ('87-'89) - which transmission model?
BobCT
Post by BobCT »
Looking to purchase a repair manual and found:
VELVET DRIVE 70c-73c
Would this cover it?
thanks,
If you have on of those transmissions in your boat it should look to see what you have . you never can tell what have untill you check thing may have been changed ,if you have the 71 or 72 I can email the man. to you
BobCT
thanks, I actually haven't bought the boat yet, will check..
Post by BobCT »
next week.
If it's not too much trouble, a copy of the 71/72 would be great. That's probably close enough for general info/repairs and would be a good start.
BTW, the boat I'm looking at has never had the trans fluid changed - it's an '88 . Possibly by a prior owner but certainly not in the past 7 years.
What's the maintenance interval on these?
thanks,
rdunne14@comcast.net
Once a year but most folks do it never or less , I will send it out to you most things have not changed . The newest fld is Dextron v ( any dextron is ok )
captain don
Post by captain don »
Wouldn"t 70C - 73C mean all years in between also? C. Don
captain don
Should have said all models in between. C. Don
Jerry
Post by Jerry »
prowlersfish wrote:Once a year but most folks do it never or less , I will send it out to you most things have not changed . The newest fld is Dextron v ( any dextron is ok )
Not picking on you Paul.... but if you look at one of the containers that the fluid comes in.... it is Dexron, Not Dextron. :D
I have been in the automotive parts business for about 27 years and only one time did I have someone pronounce it correctly.
gjrylands
Post by gjrylands »
This is a link to the service manuals for Borg Warner Velvet Drive Transmissions 71C-72C. I think it covers all models up to 1986.
http://www.marineryachts.com/borg_manual.pdf
Gerry
1979 F36 Twin Chryler 440's
You are correct and I been in the business longer then you . I should know better ,But when you hear it called dextron 99.99% of the time it rubs off :lol:
It was easier when it was type A or type F :D ( now I am showing my age
Jerry
Post by Jerry »
Wow.... Type A. I have not heard that in a very long time.
Told you I have been around for a while
