10m mid cabin express ('87-'89) - which transmission model?
Looking to purchase a repair manual and found:
VELVET DRIVE 70c-73c
Would this cover it?
thanks,
thanks,
If you have on of those transmissions in your boat it should look to see what you have . you never can tell what have untill you check thing may have been changed ,if you have the 71 or 72 I can email the man. to you
thanks, I actually haven't bought the boat yet, will check..
next week.
If it's not too much trouble, a copy of the 71/72 would be great. That's probably close enough for general info/repairs and would be a good start.
BTW, the boat I'm looking at has never had the trans fluid changed - it's an '88 . Possibly by a prior owner but certainly not in the past 7 years.
What's the maintenance interval on these?
thanks,
rdunne14@comcast.net
thanks,
captain don
captain don
Jerry
Not picking on you Paul.... but if you look at one of the containers that the fluid comes in.... it is Dexron, Not Dextron.prowlersfish wrote:Once a year but most folks do it never or less , I will send it out to you most things have not changed . The newest fld is Dextron v ( any dextron is ok )
I have been in the automotive parts business for about 27 years and only one time did I have someone pronounce it correctly.
This is a link to the service manuals for Borg Warner Velvet Drive Transmissions 71C-72C. I think it covers all models up to 1986.
http://www.marineryachts.com/borg_manual.pdf
Gerry
1979 F36 Twin Chryler 440's
You are correct and I been in the business longer then you . I should know better ,But when you hear it called dextron 99.99% of the time it rubs offJerry wrote:Not picking on you Paul.... but if you look at one of the containers that the fluid comes in.... it is Dexron, Not Dextron.prowlersfish wrote:Once a year but most folks do it never or less , I will send it out to you most things have not changed . The newest fld is Dextron v ( any dextron is ok )![]()
It was easier when it was type A or type F
