Trojan Emblems
Trojan Emblems
Has anyone replaced/removed their Trojan Emblems? As you can see from the pictures, mine are faded and pitted. I'm not sure if they can be refinished. Also, I'm not sure how they are attached, whether held by bolts or glued on.
- Trojan.jpg (27.66 KiB) Viewed 6550 times
- 11 Meter.jpg (28.92 KiB) Viewed 6550 times
1989 Trojan International 11 Meter Express
Re: Trojan Emblems
I believe (but cannot confirm) they are held on with a double stick butyl tape.
Re: Trojan Emblems
Thanks. I'll try using fishing line and heat to get them off.
Re: Trojan Emblems
mine were held on with a strong double sided tape. used a heat gun and putty knife to remove mine but I knew I would be painting it . fishing line and heat sounds safer.
Todd Pote
1987 10 Meter Mid Cabin
Double Pote-N_Sea
Double Pote-N_Sea
Re: Trojan Emblems
What did you end up doing? Replacing the emblems or refinishing? Mine a pretty pitted.
Re: Trojan Emblems
I had mine sandblasted and then I re-painted them. Silver metallic, black with a brush and then clear coated. That was 4 or 5 years ago and they need to be re-done.
Re: Trojan Emblems
Todd Pote
Double Pote-N_Sea
Double Pote-N_Sea
Re: Trojan Emblems
Awesome! Do you recall how you got the emblems off? What was the process to restore them?
Re: Trojan Emblems
For replacements try greatlakesskipper.com or kendor marine. They have a lot of emblems found my 74 trojan emblems there.
Re: Trojan Emblems
I just used a putty knife. i knew I'd be sanding ,patching and painting so a delicate touch was not required. I would try a heat gun and a plastic putty knife, they should come off fairly easy.
Todd Pote
Double Pote-N_Sea
Double Pote-N_Sea
