Trojan Emblems
Interlude
Trojan Emblems
Post by Interlude »
Has anyone replaced/removed their Trojan Emblems? As you can see from the pictures, mine are faded and pitted. I'm not sure if they can be refinished. Also, I'm not sure how they are attached, whether held by bolts or glued on.
11 Meter.jpg (28.92 KiB) Viewed 6557 times
1989 Trojan International 11 Meter Express
Re: Trojan Emblems
I believe (but cannot confirm) they are held on with a double stick butyl tape.
Interlude
Re: Trojan Emblems
Post by Interlude »
Thanks. I'll try using fishing line and heat to get them off.
yorklyn
Re: Trojan Emblems
Post by yorklyn »
mine were held on with a strong double sided tape. used a heat gun and putty knife to remove mine but I knew I would be painting it . fishing line and heat sounds safer.
Todd Pote
1987 10 Meter Mid Cabin
Double Pote-N_Sea
Interlude
Re: Trojan Emblems
Post by Interlude »
What did you end up doing? Replacing the emblems or refinishing? Mine a pretty pitted.
BobCT
Re: Trojan Emblems
Post by BobCT »
I had mine sandblasted and then I re-painted them. Silver metallic, black with a brush and then clear coated. That was 4 or 5 years ago and they need to be re-done.
yorklyn
Re: Trojan Emblems
Post by yorklyn »
Here are some old vs new with pics of the back of the old emblems showing the old adhesive
Todd Pote
Double Pote-N_Sea
Interlude
Re: Trojan Emblems
Post by Interlude »
Awesome! Do you recall how you got the emblems off? What was the process to restore them?
bshive95
Re: Trojan Emblems
Post by bshive95 »
For replacements try greatlakesskipper.com or kendor marine. They have a lot of emblems found my 74 trojan emblems there.
yorklyn
Re: Trojan Emblems
Post by yorklyn »
I just used a putty knife. i knew I'd be sanding ,patching and painting so a delicate touch was not required. I would try a heat gun and a plastic putty knife, they should come off fairly easy.
Todd Pote
Double Pote-N_Sea
