Port engine won't stay running
- daylategeorge
Hi Guys,
Having a problem with my port engine staying running. It cranks,fires, and runs as long as I hold the ignition switch up but as soon as I let it go it shuts down. Did this once a couple of weeks ago but then was fine after that. I went to fire it up today and it did it again. Should mention I had a leak in the raw water hose going from my heat exchanger to the riser the first time it happened but have since repaired it. Any ideas? Sure could use any suggestions. Thanks!
Forgot to mention I'm running Chrysler 360's built in '77 in a '78 F32.
1978 F 32 Lilli's Pad
2008 Larson Cabrio 260
horhay1946
Re: Port engine won't stay running
Try checking the ballest resistor. You should have about 8 volts when in the run position at the coil and about 12 volts while cranking. It could also be the ignition/start switch.
1985 Mako 258 (One Owner)
1981 Trojan Tri Cabin
George
George
I second the ballast resister, typical of old Chryslershorhay1946 wrote:Try checking the ballest resistor. You should have about 8 volts when in the run position at the coil and about 12 volts while cranking. It could also be the ignition/start switch.
Barrie
Aylmer Ontario, Canada
36' Tri-Fly "The Obvious"
davidsmith
Mine was a bad ignition switch
1977-F36
22`Aquasport
1969 18` Donzi 2+3
22`Aquasport
1969 18` Donzi 2+3
I'll also say ballast. Chrysler was famous for these issues. You should carry spares...they're cheap enough.
- daylategeorge
Thanks guys for the responses. As it turns out it was the ballast resistor. I changed it out after not getting any reading on my meter and she fired right up, AND stayed running! Good job guys! Thanks again. Oh and Striperman, you can bet I'll be carrying spares from now on!
daylategeorge wrote:Thanks guys for the responses. As it turns out it was the ballast resistor. I changed it out after not getting any reading on my meter and she fired right up, AND stayed running! Good job guys! Thanks again. Oh and Striperman, you can bet I'll be carrying spares from now on!
Hey I'm curious...is your starter starting to go on your port motor? I was having same problem...going through ballast resistors occasionally...I'm convinced it was because my starter was on its way out...cooking the resistor???
I replace the starter last week (8+ hours of pure enjoyment)...
The starter should not effect the resistor
