Chaning the cabin door lock on 1990 12M International
tcollins2
Post by tcollins2 »
I just bought the boat and I think I want to change the lock on the door. Has anyone done this yet. Can I just change the lock cylinder or do I replace the entire lock?
Re: Chaning the cabin door lock on 1990 12M International
Most times you can change the cylinder ( not sure your exact lock ) You can also have it re keyed
S.A.M.
Post by S.A.M. »
If it's a sliding door like on my '90 10M, it's nothing more than a patio sliding door lock. I went to lowes and bought a complete kit.
Sherman
'90 10m Midcabin
Flyboy
Post by Flyboy »
My 10 Meter does not have a sliding door latch from Home Depot. Mine is broken and I would like to replace it, but I have no idea how to get it off or change the cylinder, neither does Bob at Beacon Marine. If you figure it out let me know. Good Luck.
Flyboy wrote:My 10 Meter does not have a sliding door latch from Home Depot. Mine is broken and I would like to replace it, but I have no idea how to get it off or change the cylinder, neither does Bob at Beacon Marine. If you figure it out let me know. Good Luck.
I'd wager that John Leed could help, or even have the part(s) needed
Flyboy
Post by Flyboy »
Don't want to highjack the post, but how do I get ahold of John Leads.
Check with Beacon marine (site sponsor ) he also can get what john has ( They deal with each other ) Bob is easier to get hold of
Flyboy
Post by Flyboy »
Okay,
I talked to Beacon Bob and they got the drawings out and they have no idea how to get the latch off either.
Will keep trying.
Can you post some photos ?
bjanakos
Post by bjanakos »
Usually you take the latch cover off and there are some set screws inside.
Flyboy
Post by Flyboy »
Here are some pictures of the latch on my 10 meter. I have removed the 4 screws from both sides of the latch but nothing comes apart, the plastic pieces just wiggle around.
tcollins2
Post by tcollins2 »
I took your advice, took the lock off and gave it to a locksmith for a day. He rekeyed it for $20. He said it's a very simple lock cylinder.
McMomX6
Post by McMomX6 »
tcollins2 wrote:I took your advice, took the lock off and gave it to a locksmith for a day. He rekeyed it for $20. He said it's a very simple lock cylinder.
I have the same lock on my '86 Mediterranean sportfisher and the lock no longer works (it's just stuck fast)...I can't get the lock out either. How did you manage to get it all apart? Thank you in advance!
tcollins2
Post by tcollins2 »
There were two screws on the inside of the door that I took off and that was it.
Flyboy
Post by Flyboy »
Did it look like the lock above?
