Black water tank location
Reel Easy
Post by Reel Easy »
This may be a dumb question but. I have a 78 F-32 Express. I was looking into the plumbing system trying to track down everything.I found everything but shore water and Black water tank. How do I know if the boat even has a black water tank? Someone put in a porta potty with a drain hose on it but I cant tell where it goes. Maybe just to the pumpout on the starboard side? Maybe a tank? Any input would be greatly appreciated.
Dustin
1999 360 Express twin 7.4
Catawba Island, Ohio
comodave
Re: Black water tank location
Post by comodave »
The holding tank in my F32 is under the vee berth.
Trojan has been sold
Au Gres, Michigan
Black under V berth. Shore water port side under the side panel on aft deck under the window extension.
It may have not come with a black water (holding ) tank . My F36 did not have one , It had a recirculating head with a built in holding tank in was plumed in to the pump out lines . I had to add the tank .
CaptG
Post by CaptG »
My 75 F32 express has vacuflush, which yours may have had before porta potty, and waste tank is on center line just aft of motors. Water in fitting is port side stern in cockpit.
Gary
Miss Vicki
10 meter international express
F32 express
S. Haven, Mi.
jordan
Post by jordan »
My 77 F32 is under the V berth.
SHEGAVEIN (F-32)
Capt. Jim Jordan
Reel Easy
Post by Reel Easy »
Ok thanks guys. I looked and it appears I don't have a black water tank. I will be installing one. Would it be better to install it outward of the starboard engine? This is close to the head and pumpout. Or put it in the middle just aft of the engines? My fuel tanks are to the rear not to the sides.
Dustin
I would put it on the center line of the boat even weight distribution.... there is a genny in my boat at aft wall of engine room. What's wrong with under the V berth... there should be a floor already there to take it...
You seem to be planning to have most of the weight aft of midships......
Reel Easy
Post by Reel Easy »
I was just thinking under the V-birth that it would be alot of hose to and from the head. Where is your head located?
Dustin
