Height of a 1977 TriCabin
Wulfmoon
Post by Wulfmoon »
Hello I'm new here. and need some general info. Does anyone know the height of a 1977 Trojan tri-cabin fly-bridge. Thanks
Live life to the fullest. Enjoy time with friends
Re: Height of a 1977 TriCabin
Are you talking air draft? Looking for trailering clearance? What? I've measured my air draft, but I do not recall off-hand what it is. Can look for you in a few days.
Wulfmoon
Post by Wulfmoon »
Found out that a F36 is 16 ft so F38 should be the same.
There are 2 F36 tri-cabins the reg one ( like in pdoggs avatar ) and a tri-fly The height may be different . There is also a F36 convertible ( sport fish ) . They did not make a F38 of any kind .
Are you going to keep the boat in Pocomoke City MD ? I just drove thought there through about visiting by boat .
Barrie
Post by Barrie »
I just had my Try Fly moved on a boat hauler, and I can tell you with the keel 6" off the ground the tallest item was the wheel in the upper deck at 14'-0"
Once removed the total height was 13'-6".
Barrie
Aylmer Ontario, Canada
36' Tri-Fly "The Obvious"
Wulfmoon
Post by Wulfmoon »
Thanks for all the help. I was given the same info about removing the flybridge to get the clearance. However for right now I'm going to keep the boat where it is and just do the repairs there.
