Shift Cable
Shift Cable
I need to replace the port shift cable from the bridge to the lower station on my 1978 F30. Sadly the cable does not have a length stamped or printed on it. Do any of you know the length of this cable, i am guessing about 20 to 21 feet. Any advice or tips on how to replace this would also be appreciated. Is this something that i should leave to the Marina or attempt myself?
Re: Shift Cable
I know you said you've looked...but there must be some print on the cable. It will say something, somewhere. But, give Bob a call at Beacon Marine and see if he can help. I am sure he has the specs for you. 609-713-4602
Re: Shift Cable
Thanks, I will call Bob, my original plan was to tape the new one to the old and pull it through, but if i don't know the length I guess I guess I will tape a fish tape so I can pull the old out and measure it and then pull the new one through with the fish tape. I am kind of concerned about how tightly the passages are backed with wire and cables, any tips or thoughts would be appreciated.
- lawyerdave71
Re: Shift Cable
Yeah it will be a tight fit.
But if you are going to do one, I would recommend doing both.
What happened to the cable? Mine are stiff. I oil every season and it seems to help. My problem is there is a lot of cable coiled on the floor so if you are putting oil in, it doesn't get very far because of that coil.
Captain Dave -
1978 F30 Flybridge Express
- ready123
Re: Shift Cable
How do you oil them, under pressure? I have yet to be stumped by stiff cables as this has always solved them.lawyerdave71 wrote:Yeah it will be a tight fit.
This is what I do, make your own as below:
Directions for a Throttle and Shift Cable Oiler
You need a foot and a half of 3/8 ID reinforced plastic hose from Lowes, a tire valve, three hose clamps, a tire pump or small 12 volt air compressor with a gauge, and some MMO (Marvel Mystery Oil).
Shave the tire valve down and clamp it in one end of the hose.
1. Remove the fittings from one end of the cable.
2. Put 3 inches of Marvel Mystery Oil in the hose for every 20 feet of cable length.
3. Double clamp oil filled hose over cable.
4. Apply and maintain 50 PSI of air to the tire chuck. DO NOT EXCEED 50 PSI.
5. It will take 10 to 30 minutes for oil to appear at the other end, then your done. Have rags to catch the oil if your in a sensitive area.
I suggest safety glasses just in case somethings blows apart, but I have never had a problem. My save rate on cables is about 75%. I did all my cables every 2 years as PM (preventative maintenance) but I was not on salt water.
Scorpion07
Re: Shift Cable
Ready123...... Excellent DIY tutorial!
I was planning on putting a new cable on to remedy a sticky upper helm throttle, but thought I'd try this first.
So I did it today and it went off without a hitch. It helped quite a bit with my sticky cable, and it was easy enough that I'll do it to the rest as soon as I get some more time.
Thanks for the tip.
Thanks for the tip.
- ready123
Re: Shift Cable
Glad it worked for you. One of mine was quite bad and repeating it a second time made it like new. Now I do it as a start of season item.....Scorpion07 wrote:Ready123...... Excellent DIY tutorial!
Thanks for the tip.
Re: Shift Cable
Bringing this back to life. You disconnect the cable from the shifter and then blow the MMO through that end? Am I reading that correctly?
1974 f32 Sedan
Twin 233 Mercruisers
Re: Shift Cable
I believe so
Re: Shift Cable
Dangar Marine on youtube has a tutorial that sounds like the same strategy. I've been meaning to try it on my upper helm throttle cables.
https://www.youtube.com/watch?v=_j2xD_8k5yo
Joel
1984 F32 "Second Course"
Belle Maer Harbor, Harrison Township, MI
- AwayOnBusine$$
Re: Shift Cable
I don't want to assume, but is this the same procedure for the upper station shift cables.
F32 Fly 1975
Re: Shift Cable
Yes
