leaking stering
lasker
leaking stering
Post by lasker »
helm is leaking ..unit no longer available.. stopped making it 30 years .any advice or ideas 321 79 trojan
1979 321 Trojan
Re: leaking stering
Teleflex has a system called SeaStar that is essentially the replacement for what you have now. I believe many others on the forum have swapped out original steering for this system. If you are dual station I don't know if you can just replace the helm pump unit, or if you have to replace both of them.
g36
Re: leaking stering
Post by g36 »
when i still had my f32 i tried a repair on my syten unit i had found on the internet but the housing cracked during the process so i changer to a new seastar. i replaced only the lower helm with a new seastar pump.i had no issues and it operated perfectly fine with no changes at all to the existing parts/valves. just make sure you put the correct (nonvented) fill plug on it on the lower helm, the boat is still at my marina and the new owner has had no issues either.
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
lawyerdave71
Re: leaking stering
Post by lawyerdave71 »
I had to replace my lower unit as parts were no where to be found anymore.
Good luck with it!
Captain Dave -
1978 F30 Flybridge Express
