F-36 bow core repair
I am finally posting my project from last summer. After several years of watching the bow core getting softer, I decided to tackle the project myself. I started with drilling several holes to assess the damage. Unfortunately, the damage area was larger than I thought. I used a dremel tool to make all cuts which worked very well. I have had experience with fiberglass work over the years but never with replacing a rotten core. This was my first time using the West Systems. Using the West System to wet out the new core and 6 layers of glass was relatively easy. Since it is not fully compatible with gelcoat I decided to finish with Kiwi Grip. The bow pulpit has been installed and the only thing left is to install the hawse pipe. I have attached some pictures of the various stages of the project.
Now I cannot wait until boating season.
Bill Davies
1988 F-36
Middle River, MD
Bill Davies
1988 F-36
Middle River, MD
Re: F-36 bow core repair
I would like to see the photos . btw Welcome to the forum ? There are at least 4 others here from Middle River . a F36 conv , 2 tri-cabins and 10 meter that I can think of . What marina are you at ?
- P-Dogg
Yeah -- what Prowlerfish said!
Looks like the pictures are now posted. In the early stages of the project I thought I would try Git Rot. It did not work as I had about a 6 inch void around the hawse pipe. The Git Rot pooled in some of the void and did not provide any stability as it was almost impossible to completely dry out the wet balsa. As it turns I decided to fix it the right way. The test holes allowed me to estimate the extent of the rot. Trying Git Rot just added to the job as I had to chip out the dried Git Rot before starting the fix. I used a vibrating multi tool for all cuts in the balsa and removing the git rot. The dremel and the vibrating multi tool were fantastic. The other key tools were a grinder and a dewalt sander with a shop vac attachment. The pictures with the balsa are the dry fit in the early stages. I had increase the size to remove more rotten core that was under both bow cleats. As it turned out the patch was almost round as I did not want to have a problem with future stress cracks.
We are located on D Pier at Baltimore Yacht Club.
Bill Davies
Bill Davies
Nice job !
very nice job, I am sure there had to be a bit more mess during the project, but respect you on how clean you kept everything during the job
1984 Silverton 37C
Silver Lining
Scott
Silver Lining
Scott
Nice work! came out really nice
- P-Dogg
Yes -- nice work. Three forum members with 50 feet of each other over in Frog Mortar Creek. When I need to haul out, I do it at Sue Island. http://www.trojanboatsforum.net/wforum/viewt ... ous#p69022 John Stump over at Blue Water Marine is (almost) the only other person to have worked on my boat in the almost two years that I've had it.
Thanks for posting the "how-to." I think it helps give people confidence to tackle their own projects and keep the brand alive, not that the Dougnash and Yorklyn types need any such encouragement! I look forward to seeing you around the forum and the creek, maybe at the not-on-the-fourth fireworks at that "other" yacht club around the corner if you go there.
Nice Work. Photos tell the story well.
willietrojan
Good looking job!
Here was my experience with core issues, http://www.trojanboatsforum.net/wforum/viewt ... highlight=
Spanish Fort, Al
Looking for 33 International
Spanish Fort, Al
Thanks all. Willietrojan, I read your post numerous times. It was very helpful in deciding to tackle the project. It is nice to share some of the thoughts on the challenges and opportunities of almost any project needed on all the different trojan models.
Bill
Bill
