Trim tabs set up ?
- gordd
Trim tabs set up ?
Hello , does anyone have any pictures they can post of what their trim tabs pump set up looks like on f25 or similar . I finally bought pump and trying to get some ideas on where and or best way to install it. Thank you in advance
- The Dog House
Re: Trim tabs set up ?
I don't have any pictures but my trim tab pump is mounted in the middle of the inside of the transom.
- lawyerdave71
Mine tooThe Dog House wrote:I don't have any pictures but my trim tab pump is mounted in the middle of the inside of the transom.
Captain Dave -
1978 F30 Flybridge Express
Different boat but mine is just forward of the rear (rudder ) hatch .
- gordd
Ty everyone . There is spot where looks like it was set up before.. closer to port side between fuel tank and stern of boat. May just leave it there
This picture was not taken specifically for the pump however you can see it installed on the transom on the port side of my F-26. Its mounted to the vertical stringer with a home made 304SS bracket.
Hope this helps.
Hope this helps.
- gordd
Ty Paul .. I am going to attempt installing pump over the weekend.
