F-25 fresh water tank
Where do you fill the fresh water tank on an F-25?
- The Dog House
Re: F-25 fresh water tank
My F26 has a deck fitting on the port side near the front window to fill the water tank. I'm not sure if the F25 is the same or not.
Thanks TDH. My fuel and waste figttings are on the port side. Next time I'm out I'll look closer towards the bow.
- aaronbocknek
as on any vessel, there should be a clearly marked deck fitting that says WATER engraved on the screw cap fitting. not exactly familiar with the f-25, but all trojans had engraved deck fittings.
Thanks!
summer storm
On the early 25's (wood deck) there is a cover plate on the cockpit deck under the port side seat. If you lift up the plate you can open the top of the water tank and stick a hose in.
Doug
1977 F-32
1982 Chris Craft 280
1974 F-25 (Sold)
1979 F-26 (sold)
1977 F-32
1974 F-25 (Sold)
1979 F-26 (sold)
