chartplotters
chartplotters
Got to get a new plotter ,cannot make up my mind.as usual far too many choices.I am confused by what charts come loaded and what need to be bought after.Boating in geogian bay,the trent and lake ontario.Any help would be great as I am getting back into boats after a 20 year break.last high tech thing we had was a manual loran c.What is everyone using. Thanks. Mike
- Muskokan345
I am on the Trent and I like the Standared Horizon cpv350. On my little 26 it eliminates the need for a separate radio, although I still keep a hand held back up, Packs a lot into the unit, and can be surface or flush mounted. Having said that, there are a lot of people on this site with tons of good advise! Good luck!
1986 F26
I also have a Standard Horizon, but not the combined model. I don't like the fact that if you lose one because of a problem, you're out both.Muskokan345 wrote:I am on the Trent and I like the Standared Horizon cpv350. On my little 26 it eliminates the need for a separate radio, although I still keep a hand held back up, Packs a lot into the unit, and can be surface or flush mounted. Having said that, there are a lot of people on this site with tons of good advise! Good luck!
I prefer to keep my radio and chartplotter separate.
But have been happy with the SH for now.
http://www.cbyc.ca/
http://www.cbyc.ca/
chartplotters
got an email from garmin --they say that all the units sold in north america only come with U.S. stuff---canadian is extra---prbably the same for lowrance---have to check with standard horizon though---thanks for the responses so far---like the look of the garmin though---have garmin for the car and it is great---mike
To answer your original question...Garmin, Garmin, Garmin, Garmin, Garmin. even if you need the xtra for map cartridge, it's well worth it. Easiest to use and navigate with.
Uh, did I mention Garmin?
Chartplotters
So stripermann, you are saying that garmin is the one I should get. Lol.actually the extra 160or so is not too bad if it works anything like the auto stuff.thanks for the response...Mike[/quote]
Stripermann2 wrote:To answer your original question...Garmin, Garmin, Garmin, Garmin, Garmin. even if you need the xtra for map cartridge, it's well worth it. Easiest to use and navigate with.
Uh, did I mention Garmin?![]()
Or go with my pick Garmin
Even the garmin charts are better IMO .
No one else on here will agree with me but I would suggest going with a GARMIN.
I have the 740s on the bridge and an older garmin at the lower station. The older one is from the early 90's and still works good.
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
~DarkNemesis~
I got a garmin 441s a while back for my small boat and loved it, Although I didnt like the split screen. Its not a big unit like most big boats have but it was affordable. I bought a second one so I didnt have to use the split screen. You can also hook up the network hubs to allow added equipment. They are pre-mapped from Alaska to the Carribeans. Mainly all USA I suppose but you can probly add Canada...Anyway im just another vote for Garmin
Mike, you should also check the boat show in January. All the players will be there to strut thier stuff and answer your questions but the bottom line will be the lining in your pocket
