The windlass works one time and not another. Checked power to the unit and through the switch. I think unit is just going....do you think? If I have to replace it can anyone recommend a good replacement for a good price, I what to be able to control from the helm, my current one I release with a clutch and real in with a foot button on the pulpit. I have a 1991 12 meter.
Thanks!
Patrick
Windlass problems...electrical
As Paul said, more info would help. If the unit comes with a solonoid pack, chances are that may be your problem. Contacts tend to corrode or burn causing intermitent operation. Check for that before spending money on a new system.
The motor on my "Good" windlass, last boat, went after doing the same things as yours. Was an easy fix and around $200
Ron
Ron
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
I had to do a lot of testing/rewiring on my windlass a couple of years ago. My powerprobe puts out 12v but didn't provide enough amperage for the windlass. I bought a 12v lawn mower battery at Pep Boys and used it a bunch of times at the windlass and switch.
It's small enough to move around easily.
