f36 toilet installation - no plan
Has anyone had any luck installing an electric toilet on a F36 - I would like to install a holding tank and Purasan, but can't really find a good place to put anything..............
Buckknekkid
lotsa room
there is a lot of room under the Vberth, tons under the galley and out board of the watertanks. the inlet is forward port side but you can locate the tank anywhere even stbd.
F36 ~
SHES SOLDDDDDD
SHES SOLDDDDDD
I put a electric Ratan head in and a 40 gal holding tank in . I put the holding tank under refrige. had to move the refrige pull up the floor and cut then replace 1 floor suport . Took a full day by myself to do it if I recall . one question what is a Purasan ?
