holding tanks
wowzer52
holding tanks
Post by wowzer52 »
Does anybody know if Trojan installed holding tanks in the F-32 from the factory and if so what year did they start putting them in and where and what size. Trying to help a buddy of mine find his through hulls for his septic system so we can rework it.
1975 F-32 "SIMPLY BLESSED"
Wowzer can't you just follow the lines and smell :lol:
foofer b
Post by foofer b »
Alex, he should " Follow the brown brick road"
MY CURRENT FLEET
2003 KEY WEST 2020 WA
1978 14' ASHCRAFT SKIFF
wowzer52
I have heard people say the tanks are under the v birth . Or he could have a set up like my F36 did where the tank was built in to the head it self , I have seen other trojans like that ( all mid 70s boats). so you maynot find a tank per say. they may have changed the setup in diffrent years . Hope fully some F32 owners will jump in .
I have one centerline in the v-birth. Not sure what year they started installing as standard or as an option but my guess is around 1980.
g36
Post by g36 »
on my 78 f32 my holding tank is under the v berth. however i use a purasan unit and pump over board but can change the y valve to the holding tank if needed.
. i belive my boat came originally with a monomatic recirculating head with a pump out
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
wowzer52
Post by wowzer52 »
We know where everything is except the overboard seacock. My holding tank is an add-on which is in the closet but in my buddies 84 F-32 the tank is under the v-birth. What size hoses/seacock is your outfall and raw water intake? We are trying to find the overboard thru-hull. Where do you think they put it on the 84 F-32?
On my '85 the overboard discharge seacock is in the forward bilge. As you enter the v-berth, pull up the carpet, lift up the access board and that's where mine is.
Someone may have run it under the starboard bunk. Lift that up after removing the bedding towards the SB hanging closet.
Or...maybe there is no OB discharge at all. Just the pump-out hose going to tank.
g36
Post by g36 »
3/4 inlet and 1 1/2 discharge
mine are under the access hatch forward bilge
1997 CARVER 405
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
gettaway
Post by gettaway »
Holding tank in mine is under the V-berth in the bow, the through hulls are under the step in the forward cabin, total of 3, 2-1-1/2" and 1 3/4 "
I think Trojan saved fiberglass and gelcoat by installing 5,000 through hulls in the boat...... they're are everywhere!
3 for head system
1 for holding tank vent
2 for engine raw water intake
1 for transducer
1 for bait tank intake
1 for galley sink drain
1 for head sink drain
2 for bilge pumps
2 for cockpit deck drains
4 for 4 fuel tanks vents
1 for water tank vent
1 for bait tank supply to tank (long gone)
wowzer52
Post by wowzer52 »
Thanks guys, I'll keep looking.
Gypsy
Holding tank
Post by Gypsy »
Wowzer52,
On my '86 10 Meter the holding tank is glassed in between the stringers just foward of the battery boxes and aft of the engine room :roll: foward bulkhead. The three-way valve is on the starboard hull about 18" from the foward engine room bulkhead. I made this discovery from a picture on this forum though I can't remember which thread! Maybe this will help!
Mike
1986 10 Meter Sedan, 8.2L Detriot Diesels
