Hour Meter
fourreins
Hour Meter
Post by fourreins »
My hour meter doesn't work and I would like to replace it. Is it possible to some how advance the new meter so the numbers will match the old one when it Quit?
randyp
Post by randyp »
Not sure if you can advance it manually, but you could hook it up to DC current and let it crank until it reaches the old number. I replaced mine and simply noted the old hour meter reading on a label located next to the new one. Also keep a log with hour meter readings and dates.
Randy P
1977 F-26 HT
"Blue Heron"
Its possible but not easy . they are made tamper proof . How many hours ? if only a few hundred you can leave it hooked up to 12 volts, a week gives you 168 hours .
what most folks do is just log the hours the meter was changed at
Wes
Post by Wes »
What they did when they replaced our starboard engine was wire tie the old meter to the new engine and install a new meter.
rbcool
Post by rbcool »
Wes wrote:What they did when they replaced our starboard engine was wire tie the old meter to the new engine and install a new meter.
Now that's an Excellent idea Wes
Ron 8)
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
Torcan
Post by Torcan »
I am confused, why would they tie an old meter to a new engine? Wouldn't the new engine have 0(zero) hours?
What am I missing. Forgive this noob, but it just doesn't make sense.
http://www.cbyc.ca/
That way you won't loose it and can show its hours to a buyer
rbcool
Post by rbcool »
Maybe the old meter would show a perspective buyer the total hours on the tranny. But I think this a terific idea for foureins
Ron 8)
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Wes
Post by Wes »
If you have only one engine you don't need the old meter. If you have twins it shows the hours for the old one.
You don't have a meter for each engine ?
fourreins
Post by fourreins »
my 10.8 international only has the one meter!
Wes
Post by Wes »
Our 10 meter has only one meter also.
I have one for each engine . I have always had one per engine or none . I would have added another one when I replace the engine
Wes
Post by Wes »
I guess they don't trust you with just one.
One meter is just being cheap IMO shame on Trojan I would have added another one when I replace the engine so I would have one per engine
