Underwater transom lighting
- tsawyer
I'd like to install some underwater transom lights. There appears to be many options and many manufacturers. Some through hull and some not. Some are LED and some are not.
The marketing pictures all look very nice, but I want to hear from anyone that has done it or had a friend do it.
How many do you think I would need for the back of my 10 meter (13' beam)?
Thanks.
Thanks.
Tom Sawyer
Rum Floater
1988 10 Meter Mid Cabin
Fort Lauderdale, Florida
Rum Floater
be careful some can get to hot when you get on plane and they are out of the water they can over heat poss burn the fiberglass . I bought a set then found that out so I never installed them . I would think LEDs would be ok
No holes in the hull for me.
When they get brighter and cheaper mine will go on the trim tabs.
Danny Bailey
I've seen some mounted on trim trim tabs. Very cool looking. Would do this, before drilling into the hull myself.
Rodman
Installing lights on the trim tabs would that cause a Resistance and performance drop ?Stripermann2 wrote:I've seen some mounted on trim trim tabs. Very cool looking. Would do this, before drilling into the hull myself.
Trojan
I suppose some. But can't imagine much...dependent on size, profile and location of the under water lamp, on the tab itself. Probably be a lot less than a dirty bottom!Rodman wrote:Installing lights on the trim tabs would that cause a Resistance and performance drop ?Stripermann2 wrote:I've seen some mounted on trim trim tabs. Very cool looking. Would do this, before drilling into the hull myself.
install them on the back of the tab.
zero resistance.
Besides that....
RESISTANCE IS FUTILE
zero resistance.
Besides that....
- ready123
When you say back you mean the top of the tab which is usually out of the water when underwayRWS wrote:install them on the back of the tab.
zero resistence.
