need suggestions on replacing JUNK chrysler ign. in my 76
need help in what direction i should take in replacing the unreliable junk ignitions that chysler thought was a good idea. the dam things didn't work in a vehicle let alone in a boat.
thanks matt
thanks matt
Ignition replacement
Hi there,
Swap out the Chrysler P.O.S. with a Pertronix electronic conversion. When you remove the points plate, make sure you inspect/lube (if necessary) the ignition advance weights and linkage. Quite often rust builds up under there and hampers the actuation of the weights and not allowing for a correct ignition advance curve. Lubricate very sparingly as excess oil under the cap is not good. I haven't met an older V8 that didn't benefit immediately for the conversion.
Cheers
Cheers
"That'll buff out." :/
If you have the stock mopar electronic ignition system I would keep it instead of using some after market stuff . The after market maybe better then points but the factory electronic ignition system is the better set up IMO . If you do change over buy a extra kit so you have parts . Not fun being stuck some where and the only place to get parts is mail order .
Danny Bailey
Danny Bailey
juswinginit
crysler ignitions
I went to local junk yard and got most of the internal parts from a 318 replaced the recterfire (think thats what u call it pushes on the center shaft) mine was almost rusted away. the pickup was the same, got new set of springs cleaned it up, lubed up the weights new cap+ rotor, runs great
