killing impellers
savanahrae
killing impellers
I have a Kohler 5E gen set in my Trojan 10 Meter. I have replaced the impeller in the raw water pump twice in the last month and don't know why they are failing. I have attached a picture to show what it looks like when it stops working. When i first replace the impeller it works fine then after several hours it stops pumping water and when I remove the cover plate there is a vane bent in the opposite direction of the others. It always seems to be in the same spot in the pump that the vane is bent backward. I have an idea what is causing it to always flap in the wrong direction at the same point but welcome feedback.
Can't tell from the pic but Kohler had issues with the housing on some of their models. Is yours plastic? A new housing or pump assembly is bronze I think...
- alexander38
Housing wore out ? Replaced one on port merc 454 did the same thing.
I don't believe that I have ever seen an impeller pump housing with an offset like that. The ones I am familiar with are circular with the impeller shaft centered in the housing. I certainly haven't seen them all but am wondering what purpose that would serve except wearing the impeller out quickly.
I work as Chief Engineer of a pump company and while we don't currently make impeller pumps, our competitors do and we have their entire product offering in our engineering lab for evaluation and none of them have an offset housing.
When the blades pass the offset, they straighten out, increasing the volume between the blades. The process of increasing the volume between two blades creates a vacuum/suction.
might look into trying a globe impeller. supposed to actually run dry for 15 minutes without damage
http://www.globecomposite.com/pages/products_impeller
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
If the pump body is plastic and above the water line, I suspect running dry for even 5 minutes will generate enough heat to ruin the body anyway. The trick is not to let them run dry. On a typical Merc Bravo application, the pump is below the water line and in a failure (and normal wear) scores the stainless steel plate even though it's submerged in water.
On a impler type pump ,If the housing is circular and the saft is centered then it wont pump very well if at all , there needs to be a offset or partly non-circular shape . some pumps have a insert ( cam)to cause a flat spot in the housing make it not completely circulark9th wrote:I don't believe that I have ever seen an impeller pump housing with an offset like that. The ones I am familiar with are circular with the impeller shaft centered in the housing. I certainly haven't seen them all but am wondering what purpose that would serve except wearing the impeller out quickly.
Danny Bailey
There is nothing in your picture that would keep the pump from working. Most engines roll backward a little when they stop and this will cause what you see in the picture but it is not a problem. Look somewhere else to find why your pump stops pumping.
savanahrae
killing impellers
Thanks for all the replies. My initial thought was in line with those who suggest a worn out housing. I think the space just past the offset (cam) is worn and when the bent vane is supposed to flex and cause a suction it is losing the vacuum and thereby not drawing water into the pump body. But i am going to check hoses and thru hull before spending the money on a new pump.
