Fridge
Looks like a Norcold
http://www.thetford.com/HOME/Products/N ... fault.aspx
http://www.westmarine.com/webapp/wcs/st ... /0/0?N=377 710&Ne=0&Ntt=refrigerator&Ntk=Primary Search&Ntx=mode matchallpartial&Nao=0&Ns=0&keyword=refrigerator &isLTokenURL=true&storeNum=5004&subdeptNum=15&classNum=372
norcold/tundra
If you have the teak top shelf above the reefer check the tundra or nova cool. They are much better than the norcold. they both fit into your present location better than a new norcold and are much more reliable units. that said my norcold ,which is original, is still going strong.
DUCHESS 1987 F36
- Paul - SW Ontario
Just ripped mine out....replaced it with a used AC/DC Norcold I had kickin around.
Turn your power for it off, in fact remove the fuse for it.
If your pump and condensor is in the engine compartment then turn on your engine room blower and cut the copper refrigerant line.
Unscrew the face place around the door...remove the door.
Tug gently, wiggle it a bit...and it slides out.
Reach in, disconnect the wiring and cut the condensor tube.
Slide all the way out, and strip the foam insulation off back side to get it out your cabin door.
Done.
Done.
1973 Trojan F25.5 - SW, ON.
2012 Triple Axle trailer
1978 C&C Mega 30' Sailboat
2014 Triple Axle trailer
2016 Highfield CL290 BL RIB
2017 20hp Suzuki 4 stroke
Paul what is the refrigerant that is being reclaimed by the bilge blower
TIKI III
1985 F32
270 Crusaders
Wet and happy
1985 F32
270 Crusaders
Wet and happy
- Paul - SW Ontario
I turned the blower on for precautionary reasons....
I had the original fridge in my boat....so I assumed it was freon.
Freon is non-toxic, but like gas it is heavier then air.
If the pressure from the line were to shoot upwards, it does displace oxygen.
If you were to inhale enough it will settle in your lungs displacing the oxygen. It would also mix with the moisture (water content) in your lungs creating making it hard to breath for a spell afterwards.
So, thought it would be best to turn the blower on as my pump and condensor were very close to my bilge blower hose end.
TIKI III
1985 F32
270 Crusaders
Wet and happy
1985 F32
270 Crusaders
Wet and happy
- Paul - SW Ontario
Guess I should of paid for a refrigeration guy to come out and try to get under my floor to safely remove any CFC'sMTP wrote:http://en.wikipedia.org/wiki/Chlorofluorocarbon
you may rethink that philosophy a little bit
Stupid is what stupid does.
Besides being against the the law to vent out freon . to cut the line is just plan stupid . If it sprayS in you eye it could freeze your eye and your blind
FOREVER !!!!!!!
DON'T PLAY WITH REFRIGERANT UNLESS YOU KNOW WHAT YOU ARE DOING !!!!!!!
FOREVER !!!!!!!
- Paul - SW Ontario
Well the fact that the fridge didn't work at all, maybe explained why nothing came out of it.
Whatever you do turtlem 1969, don't do what I did...I've been told.
Unless you had gages on it you can't tell what will happen , I just don't want to see anyone get hurt .Paul - SW Ontario wrote:Well the fact that the fridge didn't work at all, maybe explained why nothing came out of it.
prowlersfish wrote:Unless you had gages on it you can't tell what will happen , I just don't want to see anyone get hurt .Paul - SW Ontario wrote:Well the fact that the fridge didn't work at all, maybe explained why nothing came out of it.
:agree:
TIKI III
1985 F32
270 Crusaders
Wet and happy
1985 F32
270 Crusaders
Wet and happy
Not sure what you are asking , did not not say you just replaced yours ? in another post ?Bowen wrote:I am just thinking right now if someone had been replacing their fridge at the boat? What could be the best space for you to be able to put a fridge? I need to know so that I can take a good move.
