Prop size and shaft size
bowlbuds2
Post by bowlbuds2 »
Hi Guys, I'm new to inboard engines and the Trojan forum and need help. I have a F26 and the prop on it looks very small. What size, pitch ans shaft size do I need. I have a 318 in her that runs great but she moves real slow. the bottom is clean so I think I have a prop problem. Pease help. Thanks,Bruce
How many rpm can you get at WOT ?
Most likey your boat has a 1 to 1 gear and 1" shaft and came with a 13x10 or maybe a 14X10 prop .
MattSC
Post by MattSC »
The prop should be in the neighborhood of a 14x10 with a cup. Your shaft if original should be 1". The recommended WOT for the Chrysler 318 is 4000 rpm. With that setup you should be able to cruise around 17kts and reach 25 at WOT.
bowlbuds2
Post by bowlbuds2 »
Thanks for your replies. What does WOT stand for? At 3000 RPM I can only do around 10 MPH. Bruce
LSP
Post by LSP »
Wide Open Trottle
Will - LSP
1976 F32 "Donegal"
1985 10 Meter "Whakanui"
Hog Pen Creek
Middle River, Md
g36
Post by g36 »
one thing also to check would be to make sure the mechanical advance in the distributor is working properly.. i thought my 318 was running good till i got to wondering why i was only getting 2900 rpms out of one engine at wot and the other apx 3900 rpms. my boat is a f32 with 2 318's so i had some idea that something was wrong. i got to checking some things and found out that the distributor was the problem. this only surfaced at speed. it would start up run great but had no power. turns out one advance spring was gone and the other stretched. found some springs and installed them and retimed it ,now getting the appropriate rpms. just my thoughts good luck
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
bowlbuds2
Post by bowlbuds2 »
Thanks again. You guys are great to take time to help. I will check and retry. Thanks , Bruce
