SYTEN HYDRAULIC FLUID
have a small leak that is at the lower helm seal. i know there are no parts available. i do however need to make sure i am keeping the system full. the original fluids are listed in some paperwork i have but when i call napa here they have no clue. so what are you guys that have this system using?
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
It calls for hynautic steering fld. in a pich its ok to use ATF ( many do ). I would (and do) use the hynautic fld as it is the recommended stuff. it flows better then the atf at low temps . Air craft brake fld ( spec mil-H-5506)is ok to use and it is aproved.DO NOT USE CAR BRAKE FLD !!!!!
I can email you the specs and bleeding info (if you have Hynautic )
thanks for the responses no i dont have the hynautic i have the syten system. i dont know if the oil mil specs are the same i guess i can research this also.
i know that atf is not perferred and i dont have to have any as in emergency but i want to by a quart because i am sure i need to top this off. its a small leak but over time fluid will need to be added. i'll check at some local marinas. there are no marine supply stores here in chattanooga since boatersworld has now closed or i'll order off internet. i had suspected that the hynautic/seastar oil could be used but wondered about something cheaper or found locally that people might be using that have the syten system like me
1997 CARVER 405
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
This link has the flds listed
http://ww2.seastarsteering.com/SHARED/Fluid.htm
your system was discoutued in 84 , I am not sure what the oem fld was but every thing points to the same fld .
Any one have a book out there on the Syten inboard steering system ?
You can find many of the fluids listed at a airport
Many people have run ATF with out proplems . I just like using the oem stuff but is $$$
