Questions if i may!!!!!!
DANNYD310
Post by DANNYD310 »
i have a 1979 f28
#1 my boat has chain drive steering been sitting for while 2 lower chains
russted solid. lith greese, wd40,oil. no workey does anyone know where i may pick 2 up? or are they the same as a m/c i know dumb question.
#2 my last f28 did list to the right some..... but this one is a little more
checked every where inc.water tanks is there a reason that im just not seeing.
thanks
dannyd
tampa fla
pnmudge
Post by pnmudge »
My F28 lists to starboard too.... I can only imagine it has something to do with the extra 30lbs of propane stored on the bridge as well as a heavy duty radar stand.... all added to the starboard side....
We figured the previous owner compensated by using one domestic water tank at a time, draining the starboard tank before the port, because they've put an extra shut-off to the port tank.
F-28 1976
twin 318 Chrysler
For your parts needs, try BEacon MArine (the sponsor of this site) or Marine Tech in Lancaster PA
you may be able to match the chain up at a cycle shop or a place like northern or a good hardware store
gjrylands
Post by gjrylands »
I believe the chain you are looking for is a #41 chain. The first # (4) is the spacing of the teeth on the sprocket. The second # (1) is the width of the chain in eighth's. (1/8")
Gerry
1979 F36 Twin Chryler 440's
