Tri-Cabin Alarm System Question
k9th
Post by k9th »
I have been reading in my owners manual about an alarm system that alerts you to such things as low oil pressure etc. My 79 Tri-Cabin alarm system either does not function or has been disabled. I have never heard it even when I flip the ignition switch to the on position before engaging the starter.
Does anyone know where the physical components that make up the alarm system are located on the boat?
thelast322
Post by thelast322 »
It could be your buzzer is broken or disconnected. Usually the engine has a sensor that sends a signal to the alarm device. Ie...oil press, coolant temp, transmission temp. The buzzer should be located around your helm. On mine it is under the helm. They buzz as you said, as soon as you turn on the inginition :? ......
"Liberty Call"
1991 F32 Crusaders
celebrating 10+years of ownership
LandVF36
Post by LandVF36 »
On our 73 F36, the componants that make up this system were manufactured by Cole Hersey.
Here is a link to a PDF that explains how to install one / how it works.
http://www.colehersee.com/04resource/Te ... IF-132.pdf
Flybridge models had a pair of buzzers installed at both helm stations. I recently replced the buzzers at the bridge when replacing ignition switches as the old ones had corroded and no longer buzzzzzzed.
Current Fleet:
2000 Carver 450 Voyager
1994 Scout 15'
2005 Caribe LCX9 dingy
1981 16' Hobicat
k9th
Post by k9th »
Thanks for the info. I will have to look and see where the stuff is located and find our why I am not buzzzzzzing
Mine only has them on the fly brige but that could have been changed . I wish mine was louder . I not sure is I would hear my at planing speed
