teleflex leak??? DQ #2
foofer b
Post by foofer b »
The fluid in my steering unit keeps disappearing. I say disappear, because I can find no evidence of a leak. Am I missing some thing or could there have been air in the lines?? Any thoughts, comments, wisecracks?
gjrylands
Post by gjrylands »
On the top of the Teleflex steering head is the filler opening. It should have a thumb screw in it. Teleflex has a filler tube that screws in the filler hole and the other end screws on the bottle of steering fluid. With the tube installed and holding the bottle of steering fluid upside down; turn your steering wheel 20 times back and forth from lock to lock. This will purge any air out of the system. If you loose fluid after that you have a leak. You will have steering fluid somewhere in the boat. It could be leaking at a fitting, the cylinder, the steering head, or at the auto pilot pump, that is if you have auto pilot. If you are loosing fluid it’s got to be going somewhere.
Gerry
1979 F36 Twin Chryler 440's
davescarrs
Post by davescarrs »
I just had same thing. I have a pressurized system so air would also be gone, but could never find any fluid. Ended up finding out pressure relief valve was leaking. just replaced that, but have to install still to see if it solves problem.
foofer b
teleflex problem
Post by foofer b »
thank you fr all the input. I am inclined to agree, the fluid has to be going somewhere. Will investigate more closely when rotater cuff heals. Roy
gjrylands
Re: teleflex problem
Post by gjrylands »
foofer b wrote:thank you fr all the input. I am inclined to agree, the fluid has to be going somewhere. Will investigate more closely when rotater cuff heals. Roy
Why wait? You've got a good excuse. Send the misses in to look for the leak. :lol:
Gerry
foofer b
tele leak
Post by foofer b »
What a laff. That is rich man rich. Will have to execute plan tomorrow after the engine heats up good!!!
You going to move on to the boat when you get kicked out ?
foofer b
Post by foofer b »
Well that doesn't sound half bad. Spent every other week on her for 3 months this fall over in Fort Walton Beach tied up to my dad's dock. Unfortunately, the significant other had to work so she couldn't come!! Had a blast diving, fishing cruising and sleeping late!!!
