Figured out why my Head wouldn't flush***PICS inside***
My rear head is clogged beyond repair, I believe the pump has stopped creating suction. The front head had the pump replace back about 4 years ago and now I think, although it has been rebuild, it is time to replace the rear one.
What is that pump called first and where do I get a decent one for cheap, 2nd??
74' F44 Motor Yacht...
79' Carver 28' Mariner
What's the brand? Usually can get replacement parts for the pump, etc. I have a cheapie Jabsco that works fine but needs replacement parts (usually seals) about every 4 years. The replacement kit costs half the cost of the head but I'm stupid and stubborn and really don't want to rip out the toilet.
Randy P
1977 F-26 HT
"Blue Heron"
1977 F-26 HT
"Blue Heron"
I'mnot sure, I haven't looked at the pump yet. I just know it was rebuilt 4 years ago but not used for the past 3 years, so it's pretty newly rebuilt. My dad put a brand new one on the front head and it will suck you into it like an aero plane toilet. Don't know if another rebuild is what's gonna do it.randyp wrote:What's the brand? Usually can get replacement parts for the pump, etc. I have a cheapie Jabsco that works fine but needs replacement parts (usually seals) about every 4 years. The replacement kit costs half the cost of the head but I'm stupid and stubborn and really don't want to rip out the toilet.
Need more info. Make, model and any numbers you can supply. Sounds like the front unit may be a vacuflush model, the way you described it...
There may be more to your rear unit than you think, than just a pump or motor.
Perhaps you can take some pictures?
Yea, they are both vacuum flush units. Don't know any other details.Stripermann2 wrote:Need more info. Make, model and any numbers you can supply. Sounds like the front unit may be a vacuflush model, the way you described it...
My Heads have the chrome button behind the seats that you push when you go in, the red light comes on, then it turns to green then you press the pedal down and it sucks the stuff down. If you need extra water you pull the pedal up. Pretty nice when they work.
Visit Boatered.com and subscribe- it's free. You then can check with Vic Williams. He is the marine sanitation guru who can help you.
http://www.boatered.com/forum/forum.asp?FORUM_ID=5
I registered but it never sent me an email. I guess i'll have to wait for it.Stripermann2 wrote:Visit Boatered.com and subscribe- it's free. You then can check with Vic Williams. He is the marine sanitation guru who can help you.
1967 seavoyager
Raritan makes a good throne. PHE-II. Electric, easy to get kits for & easy to repair.
seavoyager36@hotmail.com
"Restless"
"Restless"
Ahhh, I see you got some help on the other board. Good luck and let us know how you make out with the problem...
