Wiring schematic for 85 Sedan aft head
OrganicC
Post by OrganicC »
Anyone willing to post the wiring (most important) and hose/line schematic for a 1985 Sedan.
Also, the aft head floor basin pump keeps throwing the switch on the main board. It wasn't pumping out the water in the floor basin, so I took everything apart cleared and it was running fine without the outlet (from the pump to the through hull). But when I attached the outlet line, it ran, then shut off (popping the switch on the main panel under the lower helm). When I reset the switch before I can walk away it pops back off. FYI the fuse on the power line to the pump hasn't popped.
1985 10M Sedan
Re: Wiring schematic for 85 Sedan aft head
I missed this post sorry. Bob has the diagrams and also owners manuals. You will need your boats ID info
BEACON MARINE @ 609-713-4602
