1988 10M Mid-cabin Horn Relay
Scott67
Post by Scott67 »
Anyone able to point me in the direction of the horn relay? I understand how it's wired into the high water bilge alarms, but still haven't located the relay itself. Found two relays behind the DC panel from inside the mid berth closet, but don't know what they serve. PO has disconnected/removed the high bilge alarms on two of the pumps and the horn subsequently doesn't work now. Trying to trace it down. Appreciate any assist.
Scott
"Speakeasy"
Model 340
Twin 454 (350hp) Crusaders
1.5:1 Gearboxes
Jacksonville, FL
Re: 1988 10M Mid-cabin Horn Relay
I am checking into it, will let you know.
There is a electric pannel as you go down the stairs it should bein there. It will be in your electrical drawings also
Scott67
Post by Scott67 »
prowlersfish wrote: Fri Dec 10, 2021 12:17 pm There is a electric pannel as you go down the stairs it should bein there. It will be in your electrical drawings also
Pulled the DC panel out and no relay there. I'll just have to hand over hand it. Thanks for the input though, I have the electrical schematic.
"Speakeasy"
Model 340
1.5:1 Gearboxes
Jacksonville, FL
BobCT
Post by BobCT »
Yes, the relays are in the mid cabin berth locker (I hinged that panel BTW and added a handle so it’s now a door).
One relay is for the horn and I believe the second is for the
windshield washer sprayers. I don’t recall which is which but the wiring diagram is clearly marked.
