I have a clicking feel when turning either port or starboard
it does not feel smooth
any thoughts
thx
rr
10 meter mid cabin steering
10 meter mid cabin
Re: 10 meter mid cabin steering
the good news is that with the transom seat removed, there is excellent access to all the rudder/steering gear.
The unique design of the International series puts the rudders entrance into the boat above the water line.
Each rudder is supported by a plastic bushing, available from Beacon Marine-the sponsor of this site
On my 10 meter there was a sharp metal burr on the bottom of the rudder base.
Over the years this burr damaged the top surface of the plastic bushing, and then into the fiberglass.
I have since repaired the fiberglass, and replaced both bushings
perhaps I can find the photos.
Additionally, there is a bolt that holds the steering ram on the fixed side.
For some reason that bolt on my boat was not stainless steel
Approaching the dock sme5 years ago, that bolt finally failed and we docked with engines only.
Otherwise, I suppose I should have first asked, is the CLICKING coming from the helm or aft in the rudder area?
Is it a Ratchet type feel at the helm ? Or is it one time when you turn ? The ratchet sound/feel is normal .
thank you
I would describe it as a ratchet sound/feel at the helm
doesn't feel right to me but if ain't broke i'm not fixing it
rr
rr
10 meter mid cabin
If your feeling what I think your feeling ,there is nothing to fix . Its the normal opp of the helm/pump .
The slight click ratcheting is normal.
