10 meter, 1984, previous posts discussed replacing versus fixing existing system. Tried porta potty for a year but need toilet. Now the question. is there a vaccu flush system, hardware etc,, that I could hook to the existing plumbing under the deck ---replacing all except the toilet in the head?? The existing system wasn't recognized by the forum in previous posts, some thought maybe Canada, As noted, it hadn't worked in years and lots of corrosion and rust. Not going to rebuild, but would consider replacing it. Don't know if today's technology has a system I could just hook to the wiring and plumbing and save the existing toilet. ???
Have decided if replacing toilet would go with electric macerator type toilet like TMC Marine Electric toilet with macerator pump or Jabsco 32010 series electric marine toilet.
Vaccuflush system
Re: Vaccuflush system
Check with Beacon marine on the vacuflush . if you go with the other heads you would have to do away with the vacuflsh .
fighterpilot
Will check Beacon Marine. Thanks for the suggestion.
I wholly support Vacuflush if it is a reasonable option for you.
