animated hull 11 mt express
hi, I read that the 11 mt express international trojan is an animated hull, can you explain to me in which part of the hull is the balsa?
Re: animated hull 11 mt express
animated ?? Do you mean cored ? Most of the bottom and I believe sides are cored with balsakapuzzella wrote: ↑Mon Jan 06, 2020 6:42 am hi, I read that the 11 mt express international trojan is an animated hull, can you explain to me in which part of the hull is the balsa?
the 11 Meter is the SLIPPERIEST of all International hulls.
RWS. I was curious about that comment. Do you know why that is?. I believe that I read that it was the best version of the Deltaconic hull, but not the reasoning behind it.
1987 F32
All Wrapt Up
Kent Narrows,Md.
All Wrapt Up
Kent Narrows,Md.
I'm not a marine engineer and do not know the terms they use, however I was told that in-water tests showed the 11 meter hull was the slipperiest of all the International series.
I don't know exactly WHAT that really means...
least drag?
most efficient?
requires the least HP to push onto plane?
I really don't know exactly what the term really means.
BEST !
least drag?
most efficient?
BEST !
It was the right comb of lenth/beam for the hull design .
