Wiring Diagram
Wiring Diagram
I have a 79 F 36. My radio was tied into whatever wire is labeled number 23. The other day my radio just shut off and wouldn’t power back on. I found a new hot spot for it and everything is fine. My question is does anyone know which wire would have been labeled number 23? Everything seems to be working fine on the boat so I’m curious to know what it was I actually lost?
- WayWeGo
Re: Wiring Diagram
Do you have the wiring diagrams for your boat? If not, you can get the full documentation package from Beacon Marine.
Re: Wiring Diagram
Thanks...I think I do and I will look but was hoping a seasoned Trojan owner would know off the of their head!
- WayWeGo
Re: Wiring Diagram
On my boat, 23 is an unused accessory circuit. Not sure why I had to pull out my documentation when you have your own...
Re: Wiring Diagram
Lol...because I’m not at the boat right now and it’s bothering me!!!
Re: Wiring Diagram
What that circuit is used for may vary from year to year and could vary with options also . Being numbered does make it a lot easier to trace .
