1978 36 ft trojan tri caben
Kevinbrideau
Post by Kevinbrideau »
Ok well I have two 30 amp and a 50 amp coming into my boat. There's a switch that switch them from one to another. I have power to that switch and nothing out. What is that switch. Where can I get one
Kevinbrideau
Re: 1978 36 ft trojan tri caben
Need help
Moderator
2026 Support
2026 Support
Post by Moderator »
I moved your post to the boat section where more will see it . Beacon marine carries a lot of Trojan parts
Moderator
Forum Moderator
TrojanBoats.Net
Trojan Boater
Kevinbrideau wrote: Sun Jun 16, 2019 4:07 pm Ok well I have two 30 amp and a 50 amp coming into my boat. There's a switch that switch them from one to another. I have power to that switch and nothing out. What is that switch. Where can I get one
Ditto on Beacon . I have not seen a switch like that on a Trojan . Most Tri-cabins have twin 30 amp . Do you have a photo of the switch ? And your Panel ?
The normal set up is 2 30amp cords 2 30amp breakers and a cross over switch in case you use 1 cord never turn on the cross over with both cords . I will tri and pot a diagram and panel photo later
