1976 Chysler 318 rear engine freeze plug replacement
Svend
Post by Svend »
Greetings...
I blew out my freeze plug behind the bell housing on my 1976 Chysler 318 F30 Express boat. Have any of you been through this. Any advice on me doing this myself? Are there any good video's out there describing the process? Thanks for any help!
Raymarine EV 100 Auto Pilot
ken64k
Re: 1976 Chysler 318 rear engine freeze plug replacement
Post by ken64k »
What caused the casting plug to come out? Did you forget to winterize the engine? You should be able to tap the brass pulg back in. If you can put the plug in a freezer than hammer it back in.
Trojan F32 Flybridge 1975
Twin Ford 351s
Albany N.Y.
Use a new plug . But why did it come out ? You may have other issues
Tgornik
Post by Tgornik »
Bump on an old post.. Any luck with this?
I have a plug leaking behind the bell housing ( port engine, plug near right head). My plan is to attempt to replace the plug by just loosening what i need to to get in there enough. I am working on an F31 and have lots more room than you i bet, but the coupling to tranny etc should be about the same. Did you find any videos? Did you have to pull bell housing out completely to get in there?
Thanks,
"You're gonna need a bigger boat!"
1973 Trojan F31 Flybridge W/ Twin Chrysler LM 318s
Paul - SW Ontario
Post by Paul - SW Ontario »
Done this job this about 5 years ago.
You will have to remove the bell housing and velvet drive, as well as the flywheel to access the the two freeze plugs.
1973 Trojan F25.5 - SW, ON.
2012 Triple Axle trailer
1978 C&C Mega 30' Sailboat
2014 Triple Axle trailer
2016 Highfield CL290 BL RIB
2017 20hp Suzuki 4 stroke
