Engine conversion
Customdiver
Engine conversion
Post by Customdiver »
I have a '72 31' that the previous owner changed the motors. one is a chevy and the other is a Ford. I have a couple of questions. 1. what would be the most reasonable Diesel motor to exchange it with and can I run one motor and two shafts? Your help would be greatly appreciated..
you only have one life, so live it to the max
Do to space your limited on engine choices Yanmar is one cummins 4BTA 3.9 is a nother, Peninsular has a 6.5 diesel based on 6.5 g.m that may work .stryr is another choice . you realy only have room for 4 cly diesels due to lenth other the 6.5 thats a V8 . you don't have room for a 6 cly in line Engine . Now I am talking twin engines as far as useing one Engine with 2 shafts yes it can be done I forget the company that made that set up ,But it takes up a lot of room . alot more then what you have .
As far as runing 1 ford and 1 chevy I do not think its a big deal . I know a F30 that ran a chrysler 318 and a chevy 350 for years . also know a F36 that had 440 chryslers and when one went bad it 1 was replaced with a 460 ford as chrysler stoped making the marine 440 and begain useing the ford engine .
Customdiver
Thanks for all the information...
I think I will have my engines rebuilt and stay with the gas.
if you are going to make the investment of rebuilds, now would be a good time to replace one of those so you have a pair of twins.
These engines have different torque curves and power characteristics.
This could be a real issue for resale both for resale price and the buyers who would reject the boat based on the two different engines.
The cost of a complete takeout core to rebuild should not be a big factor in the total rebuild cost.
I agree with RWS if your going to be rebulding anyway . but if they run fine then I would leave it alone.
Customdiver
Thanks for the advise.
The Chevy motor needs to be rebuilt. So I agree that I will replace it to match the other motor.
I am also going to convert it over to fresh water cooled as it isn't right now. My mechanic says he has all the needed parts.
