Rub Rail
davidsmith
Rub Rail
Post by davidsmith »
Hello all,
My 1977 F36 is in need of rub rail replacement. It currently has the teak wood with the stainless cap The wood is too deteriorated to refinish due to wood loss. Have any of you replaced your rub rail and if so what did you use. I have been looking at the Barbour plastics website but cant decide what style I should get. Any help would be appreciated.
1977-F36
22`Aquasport
1969 18` Donzi 2+3
LandVF36
Re: Rub Rail
Post by LandVF36 »
I've replaced some sections. I just replaced with Teak, polished the old rail, and re-installed.
Current Fleet:
2000 Carver 450 Voyager
1994 Scout 15'
2005 Caribe LCX9 dingy
1981 16' Hobicat
davidsmith
Re: Rub Rail
The top of the wood has been sanded so many times the stainless cap is right on the edge of the wood and is cutting the lines. I would really like to eliminate the maintenance of the teak and go with a plastic/rubber material.
1977-F36
22`Aquasport
1969 18` Donzi 2+3
Re: Rub Rail
My 77 F36 uses a synthetic or plastic maternal late 80s Viking also use it . Check with Bob at Beacon maybe he has it . I know Viking still had it 2 years ago . Its not real flexible so like teak maybe fun to install . There is other after market rub rails around .
Happy Ours
Re: Rub Rail
Post by Happy Ours »
My 77 F32 also has a hard plastic or synthetic material, last year I used 220 sand paper gave it a very light sanding just to scuff it up so the new paint would adhere, then 2 coats of paint looks like new.
Craig
1977 F32
1975 F26 sold
Trent Severn Waterway
rsciolino
Re: Rub Rail
Post by rsciolino »
I used the Tessilmare kit from Jamestown distributor. What a beautiful look. Use lots of muscle to install but worth it.
I looked at everything at IBEX and decided on this. All of my future projects will use this
Re: Rub Rail
Post by rickalan35 »
rsciolino - That Tessilmare product is very impressive.I'd never heard of it before. The website from Jamestown shows how it is applied. Did you do the work yourself? Upper NY?? Finger lakes or Lake Champlain region?
rsciolino
Re: Rub Rail
Post by rsciolino »
I do all my own work. It was pricey, but now I have a beefy rubrail that not only looks great but protects as well. I am in Western NY
