Please forgive the mess, but this is a work in progress...
I spent most of the day tearing out the carpet in the Salon. I am pretty sure it is original and perhaps some of you experienced folks can comment. It was some sort of synthetic material somewhat like the green-grass indoor/outdoor carpeting. It was laid down over traditional carpet padding and stapled to the floor around the perimeters. I wore a tyvek hoodie, googles, and a respirator because this stuff was literally disintegrating. I removed all of the carpeting and padding and gave it a good sweeping and vacuum, but I need to come back and scrape up some of the double-sided tape residue and do some staple removal. Regarding Staple removal... I will start with trying to pull them all out, but if it's too slow going, I'll be armed with a 3# hammer and just pound them flush.
After their removal, I noticed that there is some water ingress on the aft corners of the salon and that area of the floor is in poor shape; especially the starboard side. The starboard side from the gunwale to the door will have to be cut and replaced. The port side might be OK; I need to get underneath. The support beam for the floor/rear on the starboard side also pulled away and is laying in the bilge. I have not pulled it out yet to see what kind of shape it's in. I can see some 3" rusty screws sticking down through the door jam... I will probably replace these with stainless 1/4"-20 machine screws and fender washers for more support.
Overall, the floor is OK. It's solid and painted in primer-grey, but it is C grade plywood and the edges are a little rough especially where the staples were removed. I think a hard surface or carpeting will be a suitable replacement as any kind of vinyl will show all of these imperfections. I really don't want to get involved with filling or fitting a layer of hardboard. I have been looking around for deals on foam-backed carpeting. I think that will be the easiest and quickest method.
I got involved with some electronics work. I removed the cable raceway from the starboard side window area and the teak (mahogony?) board from above the windows. I wasn't planning on getting into electronics yet, but I think I can sell some of this older gear and recoup a few dollars at some upcoming fishing/boating shows.
The following are some examples of how bad the woodwork is in the salon and galley. It looks like some water staining was involved, but mostly I think this just has not been refinished in a decade; if ever. I think I am going to remove the doors and maybe the upper pieces on the sides and take them home to refinish in the heated shop. That way I can have them in and re-finished and not worry about spilling varnish on the new carpeting.
The PO had a folding card table that fit in this slot. You can see the difference in the color on the area that was covered and it doesn't look horrible.
