osco raisers and elbows gaskets
Please tell me the proper gasket to install on my raisers and elbows.I have gaskets with 2 holes and one hole,need to know witch one go's on the raiser and witch one go's on the elbow.I have a Chrysler 318 fresh water cooled with raw water intake.Thanks James
Oil pump shaft and gear
Need oil pump shaft and gear for a Chrysler 318 reverse rotation that connects to the distributor,any ideas where I can find one,it'sa 1976.Thanks James
Re: osco raisers and elbows gaskets
That would depend on whether your manifolds or maifolds and elbows are fresh water cooled or raw water cooled . 3 different ways I believe they have done it .James Rigby wrote:Please tell me the proper gasket to install on my raisers and elbows.I have gaskets with 2 holes and one hole,need to know witch one go's on the raiser and witch one go's on the elbow.I have a Chrysler 318 fresh water cooled with raw water intake.Thanks James
salt water go's threw manafolds ,raisersand elbowws
Then you use the ones with 2 holes
Call Osco. Tell them exactly what you have. They are usually really helpful. Lots of info of their site too.
http://www.oscomotors.com/catalog/catalog22.asp
