plastic fittings
plastic fittings
Has anyone found plastic fittings which match or can be used for the plastic water tubing in our Trojans? The original manufactorer is out of business.
Pex?
Pex tubing?
Plastic Fittings
I have used regular brass compression fittings on my 1977 plastic plumbing on the water heater lines.
- aaronbocknek
plastic fittings
i tend to agree with wowzer.... go to the rv store if you have one in your area. i have a huge one here in the baltimore/golden ring/middle river area and i have gotten a ton of things there that work just fine.
if you want their web address, just let me know.
aaron
aaron
I got them from my local hardware store when I need to replace a cracked line under the gally sink, with connectors...
I bought Fast N Tite fittings here about a year ago:
http://webcat.ryanherco.com/products/03 ... 88_089.pdf
Part numbers for 1/2":
female 662.066
male 660.066
tee 672.066
union 664.066
Hope this helps!
Brett
female 662.066
male 660.066
tee 672.066
union 664.066
Hope this helps!
Brett
Danny Bailey
really?
My 72 F32 is plastic (Pex now). Did someone upgrade before me?
I found the best places to be local hardware store (convenient) and either Lowes or HD (bigger selection, price and location near boat) It's crazy buying PVC tubing, tees, connectors, etc from marine supply houses. Another good source for some hard-to-find fitting are laboratory supply houses.
Randy P
1977 F-26 HT
"Blue Heron"
1977 F-26 HT
"Blue Heron"
