Onan impeller
- Bob Giaier
Onan impeller
I'm looking for a replacement impeller for my MCCK Onan 6.5 gen. I see on Amazon.com there's an impeller called a dry run impeller by Globe Marine model 1014. The site says it's a direct replacement for the 131 0160 impeller, but improved to withstand running dry and only $33 bucks.
Anyone out there ever use this impeller?
Re: Onan impeller
Stay away they have been known to have low flow rates .
read this thread
http://www.trojanboatsforum.net/wforum/viewt ... obe#p80721
read this thread
- Bob Giaier
Re: Onan impeller
Wow! Thanks. Not going to use that one.
Any idea where to get a good impeller for an Onan gen?
Re: Onan impeller
Got mine via ebay, one of the sellers has a large supply of onan parts after he closed his marine business. No part for onan is real cheap but available. I posted many posts in my saga of having a good running 6.5. If your pump bearing is not good look them up I reproduced the bearing which is very very spendy to buy original.
Good luck.
Good luck.
todd brinkerhoff
Re: Onan impeller
They have impellers on the Trojan store page, which is accessible from the first page you come to on this site.
- Bob Giaier
Re: Onan impeller
Thanks guys, I'll check out the Trojan store. My pump bearings and seal seem to be good. I'd like to replace thee seal eventually if I can locate a seal kit for a reasonable price. We'll see.
Thanks again.
Thanks again.
Re: Onan impeller
seal kits are available but like $150 or something near. Same places, fact pretty much everything for a Marine 6.5 is available but nothing is cheap.
Re: Onan impeller
I bought one this year and have been running no problems. Good flow. This is form the guy that has burned up two impellers in two years by being an idiot
- Bob Giaier
Re: Onan impeller
Well I bought an impeller off Amazon thinking I was buying a replacement and I received what looks like the Globe dry impeller. It has the plastic drive and it's blue.
I think since the impeller is so much smaller than a marine engine impeller, the drive pin sees a lot less tongue and hopefully might hold up. I'm going to try it.
Re: Onan impeller
Not rocket science, buy a genuine Onan impeller from wherever same for seal then no problems. I checked at my bearing supply house and they cannot find a seal of same size as Onan, it must be proprietary as is bearing but that can be reproduced for 25% of normal price. Onan parts come in, guess what, Onan packages.
