Leaky pressure relief valve on Velvet Tranny
- Jfreeman1412
Hey Guys
I'm not sure if it is a pressure relief or breather? It looks like it has a cap on it that seems like it wants to come off, but it doesn't the other tranny seems to have some pressure built up and it sealed the valve. The problem one appears to be leaking tranny fluid. Any thoughts? And what exactly is it called? Thanks.
1973 Trojan F-30 Sea-Raider-is for sale
1980 Trojan F-30 Sedan
Re: Leaky pressure relief valve on Velvet Tranny
That sounds like the vent on the top of the trans. I've seen this due to a faulty heat exchanger before. Water gets in thru the cooling line, floods the trans and forces oil out thru the vent.
Its a vent /breather .
Check for over filled fluid ( very sensitive to level ) and for water like Paul said even a little water will cause a issue .
The vent has a check valve in it to hold slight pressure ( so it could be bad ),
http://bpi.ebasicpower.com/p/ALT23331
And your using ATF not oil right ?
- Jfreeman1412
Thanks a lot guys! I will check for water tomorrow, but i have a feeling it is a bad valve. It will not build pressure like the other one. I will let you know. Thanks agian.
- 32pacemaker
that is a problem with some of the velvet drives, does it happen when the trans is cold and neutral, there is a factory bulletin on this
- Jfreeman1412
Yes, it does. Is there some where I can find the bulletin?
- 32pacemaker
there are two bulletins one from BorgWarner and one from Mercruiser one was a baffle that goes in the vent chamber I will try and find that one and the Mercruiser one that there was a different way to have the return line from the oil cooler to the lower right corner of the trans...............
- Jfreeman1412
Sounds like fun. Is there a good way to find these online?
- Jfreeman1412
Has anyone removed one of these? What is the best way to remove them? They are not threaded. Looks like they pop in and out? Just want to make sure before I attempt to replace one.
From what I remember there pressed in so they are tight fit
