Need some advice, transmission got borked on my first outing
As some of you know, I recently bought a 1981 Tri Cabin. I had the boat surveyed and mechanically inspected, and other than the need to replace the exhaust manifolds and the hot water heater, there was not a lot mechanically that either the mechanic nor the surveyor determined needed to be done.
So, last weekend,m my maiden voyage aboard. Traveled about 20 some odd miles along the Fraser River to my ne Marina. About 2/3's the way there, as you may have read in another post the port engine died and would not restart.
As I feared, it was the transmission. The seal blew and the transmission fluid rushed out, then the tranny siezed. So, now I need to wrap my head around how to get this done. I ainticipate that this is a huge task.
Has anyone here had to replace the transmission in a Tri Cabin? Does the engine need to be lifted out of the boat, or can the bell housing be dropped and removed seperately? Is there any one near vancouver who has experience and would be willing to help out a willing student who can pay you in grattitude, food and beer or whisky?
I want to get this done properly, but cringe at how much I fear it may cost to have a pro do it. Any help, guidance and advice would be welcome.
thanks in advance and Cheers.
- Commissionpoint
I know very little about the drive setup in an '81 Tri, but you can pick them out of a F-32 or F-36 pretty easilly. Assuming there is room to work it should be relatively similar in a Tri. Does that thing have V drives or just the Velvet Drives?
Trying to remember how much room there is between the tranny flange and the stern tube but I'm pretty sure it's doable with the engine in place. Really don't need very much room to back the tranny off - maybe 3" inches to clear the input shaft. If you need more room than is available, you can gain more by doing the job on land and removing the coupler, shaft, and stern tube hardware. It's that or move the engine forward. Bellhousing shouldn't have to come off.
I normally unbolt the shaft . then raise the back of the eng and trans enough to clear the shaft . then I support the back of the engine .disconnect the cooler or lines and linkage unbolt the gear and then remove it .
WARNING IT WEIGHTS AROUND 150 LBS !!!
- Commissionpoint
Post some pics of the coupler/shaft/sterntube situation if you can. That way folks can lay eyes on it and help make sure you get the best feedback possible.
Paul is right. Careful handling that thing. Its not light.
A quality rebuild and it will last a very long time. Should be able to find a qualified shop right in Vancouver. Alternatively you could do it yourself, Canucks aren't playing, gotta do something right?
+1 on all that Prowlerfish has stated, plus keep in mind before you dive in, your velvet drives are most likley your aft engine mounts, like PF said, you'll have to raise and support the aft end of the engine to get the transmission free.
I built a wood A-frame to pull my engines, the frame spanned the engines fore to aft, and I used a chain hoist to lift out the transmissions and engines, different engine location on the F-32. Also, they transmissions are VERY heavy, i think they are made from lead(kidding), it kind of fools you because they dont look very big but they are substantial
Try Beacon, plus there are a number of rebuiders who sell rebuilds reasonably with a core
good luck
good luck
1984 Silverton 37C
Silver Lining
Scott
Silver Lining
Scott
Thanks for the tip! I will keep that supplier in mind.Bigearl wrote:If you are having trouble finding a local rebuilder for your transmission J Anthony Keats in Ontario do this work. They rebuilt a Paragon V drive for my F28 and I was totally satisfied.
Bigearl
And to Prowlerfish and gettaway, thanks for the tip on the transmission serving as the rear engine mount. I will be taking some detailed photos this weekend.
Cheers,
Kai
I have not got photos uploaded yet. No net at the boat yet. That is coming soon. But I do have a better description of the state of the transmission.
The port engine's controls are stuck in neutral. You cannot move to forward or reverse positions. WHne you hit the starter you hear the engine try to turn over, but the transmission is locked and nothing will turn over when the starter engages.
So, from the sounds of it, will I have to take out the bel housing?
trojanmanXS
not sure what transmission you have but I have one that came off my boat you can have for free if its what your looking for , it came of a 440 chrysler "velvet drive tranny" I have no use for it and its yours if you need it . lemme know , as to anyone else I have all the external parts off a 440 if anyone is in need of parts. manifolds, elbows,intake , carb, starter, ect ect . good luck
rooferdave
had the tranny out of my 76 tri fly twice this year, its really no biggie, just relax, follow along with us here and you will be fine, thing about boats is in a twin engine set up one tranny pump is in backwards to allow for the counter rotating engine, a car guy will miss this... hence doing mine twice, but in and out on my boat is less than an hour each way
you will be fine
you will be fine
