I think you are talking about the white plastic ones if you check West Marine or Defender for wiper motors the covers will be listed there as optional parts, I replaced all my motors and i think i gave the used covers to Aaron, I am not sure he ever used them.
the wires are designed to run through the slot in the window frame extrusion.
However, on my model, they relied on th eactual frame for a ground which can cause problems with age.
I ran each wioer motor wore to a common heavy ground and also grounded the frame with a 10 guage wire to earth.
zero problems since doing so
