Help me bench test a wiper motor
jaahmez@hotmail.com
Hi all,
If I use a jump pack (12V)to bench test my wiper motors, which are 1984 vintage and have a single power connection, am I supposed to go positive to the connection and ground to anywhere on the motor's steel casing?
I've got a three motor set up, with three separate toggles, and none work. The fuse(s) and line(s) in are ok so I took them down to bench test them.
Thanks
James
Thanks
James
jefflaw35
If it is a one wire connection then positive to the terminal and negative to the body. In such a case the windshield frame would act as ground so look for the ground connection to the windshield frame and ensure there is continuity.
kevin babineau
kevin babineau
jaahmez@hotmail.com
Thanks for the help to all. Corroded ground(s), a little clean and sand and all three work great.
Boat's been on land for 2 seasons while I restored it in my spare time. Trying to knock out a few more items before the tractor trailer trip to the travel lift next Thursday the 16th. This forum's been a big help.
James
James
