Teak rub rail upkeep
My rails are teak for certain, the biggest pain in the a$$ is removing the stainless trim. To do the job right to either clean or sand before putting on the sykkins(spelling) the trim must be removed. If any of you guys have a better more productive idea chime in.
Dang!! No replies.... I have same issue, I am trying to figure out how I am going to do this work this fall when I pull the boat. Shrink wrap will make it impossible... But your question must be dealt with first....
Help!
Help!
1072 14 ft Meijers - Sears outboard
1990 17 ft Sea Nymph - 70 Johnson
1992 17 Tracker Deep-V - 40 Yamaha (still own)
1987 266 Cruisers Inc - 460 King Cobra
1974 F36 Trojan - Twin Crysler M400
jefflaw35
are you saying the screws are really tight in the wood? or hard to get to?
I cused mine as I disassembled the boat so bad my buddy laughed and took the wood home, Over drilled the holes to fit home decor plastic fitings. The same you would hang a heavy picture with,drywall sinkers? Cut them in half, sank them into the wood. Now I have easy replacable screw fittings. Was a good Idea I thought. Im not sure if this is what your talking about though...I may be misunderstanding.
jefflaw35
also on the 74 F-25, Trojan put the rails up with set screws, then next to that is a through hull bolt, and over that is the trim screws. 112 X 3 is what I have, Plus they screwed the hull lower and upper togather every six inches and they all needed to be tighten up, well over 250 screws. Lots of work to rub rails but well worth the effort! us a hammer drill to remove your trim screws and a good new bit, they should come right out
I do my rub rails 1-2 time a year with teak oil....I clean them with powered tide detergent w/beach. I make a runny paste and use a scrub brush. If I need to sand I use a multi-tool....it's a small sander with a triangular head, get very close to the hardware....then oil, let sit an hour (or 2 beers) wipe off and repeat next day. Whole job take about an hour of work time...1972 30' Sea Raider...............John
1998 Kawasaki ZXi 1100
John - sounds like your idea is the way to go. How do you get to the underside of the rail - I am in the water with not so good of access to the rail for this work unless I am on-deck reaching over. Top side should be a sinch, but cannot see bottom side?
paul
paul
I did mine by laying down on the dock and adjusting mooring lines to bring the rubrail alongside dock working from bow to stern on each side. i think it took three line positionings each side to complete.pwollsch wrote:How do you get to the underside of the rail - I am in the water with not so good of access to the rail for this work unless I am on-deck reaching over. Top side should be a sinch, but cannot see bottom side?
paul
I'm in a covered u-slip. I move the boat around so I can reach all around. I use an old sock saturated with oil to do the underside....I just do it by feel.......John
Mysterybay
Re: Teak rub rail upkeep
Try power washing them first. Most times you can just refinish after that with no other work. My friend and I both have 36' tri-cabins and that's the procedure we use.Tri-Guy wrote:My rails are teak for certain, the biggest pain in the a$$ is removing the stainless trim. To do the job right to either clean or sand before putting on the sykkins(spelling) the trim must be removed. If any of you guys have a better more productive idea chime in.
