Under water exhaust - Tri Cabin
JGedridge
Post by JGedridge »
Hey all,
I am taking on water when I run, and can't figure out where!!....I think that the backing board is going back on the port side where the underwater exhaust goes down. .... The back bilge pump goes off for about 5-8 seconds and not just when Im getting up on plane. Any ideas?!?!.....I am getting water in the front bilge too just from sitting at the dock, but it doesn't look like lake water because its clean, and I know that I don't have a fresh water leak anywhere. Help :?:
Joe
Mike Kulp
Post by Mike Kulp »
Aaron were are you.
Mike 1986 10 Meter mid cabin
JGedridge
Post by JGedridge »
Wheres my buddy Ron with the Trojan Ho like mine?!
Joe
vabeach1234
Post by vabeach1234 »
Have you checked your shafts while running to see your drip rate at the packing? Could be time for new packing. The drip rate while the shaft is spinning is probably different than when the shafts aren't spinning. You may have already checked this though.
Ken
1972 Trojan F26 Express
1985 Dell Quay Dory 13
Hampton, VA
JGedridge
Post by JGedridge »
Yep, shafts are fine. :(
rooferdave
Post by rooferdave »
check you rudders, at rest they may be ok but under way and under pressure also where the through hull bolts are
Exhaust is possible and don't forget to check that clamps are tight at the exhaust elbows or leaking mufflers and I believe you have a type of bellows in your application. Run engines and do a visual while in neutral and check for raw water and circ pumps leaking, all hoses, coolers etc. etc. If you don't see anything, start isolating sections of the bilge by what ever means needed to contain leaks so water stays in the area of the leak and doesn't flow somewhere else. How do you know it's not a fresh water leak? You say it's too clean to be lake water; it's either lake water, potable water or rain.
